Hi everyone
My battery seems to be draining pretty quickly, even though I'm using JuiceDefender. I'm running Android 2.2. The following info is taken while away from wifi for 80% of the day. I loose 5% of battery per hour if it is just in standby, and the battery is now down to 12% after 4 hours of actual use. No GPS, just music or mobile internet. Does this life seem normal?
Apps running constantly in the background:
UltimateJuice
Juice Plotter
3G Watchdog
Battery level 12%
Up time: 14 hours
Awake time: 4 hours
Cell standby 36%
Phone Idle 33%
Android system 19%
WiFi 8%
Display 4%
Syncing Microsoft Exchange as items arrive (Push) (note the first ultimate juice setting)
Ultimate Juice settings:
When screen off, enable data/wifi for 30s every 5m
Leave data/wifi enabled while screen on
Keep wifi disabled while not at a hotspot
Even with all these limitations, with wifi off, it looses 5% per hour just through 30s of data every 5 minutes. Can you recommend a way of making the battery last longer? Should I change my email settings? I'm using gmail.
Thanks
Andrew
UltimateJuice
Juice Plotter
3G Watchdog
Battery level 12%
Up time: 14 hours
Awake time: 4 hours
Cell standby 36%
Phone Idle 33%
Android system 19%
WiFi 8%
Display 4%
Thanks
Andrew
