Hello Android Forum,
I have a Samsung Galaxy Tab2 7.0 .
The battery seems to drain away fairly quickly, I have used the usual settings
but it makes little difference.
Am I to expect this kind of performance all the time ?
Jeffivy
Hello Jeffivy. Welcome to Android Forums. I suggest you check with the other owners of your tablet to see what is normal battery drain. Even if your up time is normal they should have some suggestions on improving that. Here is a link to the Tab 2 area. Samsung Galaxy Tab 2 - Android Forums
Best of luck to you and thanks for using these forums.
Hi there, welcome to the phandroid community. Great to have you here part of the forums. Olbriar has given you a link to the best place for you to get help with your tab. Thanks again for taking the time to join the community.
