Hello and welcome to the forums . I see your having a problem with battery percentage showing . can I ask are you rooted and have a kitkat device if kitkat .
Go to settings now to interface and status bar and check the box that has battery percentage in it .
I'm currently running an app now that shows the battery percent and has other features like the app you posted. However I'm looking for an app to set the hidden battery percent like I mentioned in my first post. My Android tablet has a check box to turn on battery percent running Android 4.1.2.
My Valet doesn't have a checkbox to turn it on hence a request for an app or way to turn it on.
Thanks for your suggestion though.
