I can not seen to find a way to display battery percentage on the top bar like I can on the GS3 and iPad. Am I overlooking something or do I have to go back to installing a separate widget for this?
No other stock Android versions have had this AFAIK. You'll either need to use a widget or find a ROM that features it. My Gnex has this with a custom ROM.
