Battery Performance Issues
Peter Hesse
Hey so when I first got my MXP running 5.1.1 I was able to get over 7-9 hours of screen on time, but when I upgraded to 6.1 (it was fine with 6.0) I'm lucky to get around 4 hours screen on time... So I flashed CM13 to see if it was Android draining the battery. I have root access using a combination of greenify, amplify and power nap (using Xposed module) but I still cant get the battery life above 4 hours sot. I'm currently at 46% and 2 hours sot...
I also tried wiping the cache partition and factory reset, but no change. Could my battery just simply be dying or would CM13 still have the same draining issue??? Any thoughts or suggestions on what I should do??
