Battery problems
Can you identify certain apps you may have loaded / installed since the last time your battery used to keep a good charge or didnt run down so fast?
Hello and welcome to Android Forums. It seems as if you have a defective battery. Your best bet would be to get a new battery. Also, you should check-in with your device's area of support.
If you need any help navigating the site, just give one of us Guides a shout!
