I have now learned from reading the forums, that battery memory is no longer an issue. Previously, I have always let my battery drain almost completely before re-chargIng. Then I would charge to "100% + 1 hour", if I could. I had understood that if you don't completely charge the battery it would learn a lower fill capacity. So I hardly ever took my phone off of the charger, once I started, until it reached 100%.
So my question is... With these newer batteries, can I take it off the charger before it has reached 100%, without it affecting the capacity? Can I do partial charges everyday when I leave work?
Ex. I roam at work and it kills my battery by the end of the day, because I need to keep data open (mostly). And I am not In one place at work, I'm all over the building. Can I partially charge in the car for 30 minutes or less everyday on my way to my next activity?
