Kevin Coleman
Hi all, a first time poster so hopefully I’ve gotten it right?
Here’s the details: We bought two S7 Edge Model: SM-G935F 32GB on 26th of October 2016 which other than being different colours (for easy identification) are identical, with an added 128GB SD card added to both.
My concern is that yesterday I compared the “remaining battery” details & found that they varied hugely. The first at 100% charge shows 42:54, 52:20, & 148.00. The second shows 13:12, 16:06, & 45:30 or around 30% that of the first! This to me at first indicated a faulty battery.
However, testing (albeit brief so far), seems to indicate the discharge rate (standby with no usage) to be basically identical. After 3 hours they both show 94% remaining which looks to be fine?
I’ll continue to do ongoing testing to find out the true discharge rate. BTW the second (low readings) phone has MAXIMUM power savings enabled wherever possible & both phones have pretty much the same apps installed. The first phone has default power savings set.
I would just like to hear what others think of this & should I approach Samsung since it does appear to be a fault in some way?
