Battery Saver Specialist
johnsmith68
No-Posting Probation
Fast charging is a free battery saving app that makes your battery last longer. With Battery Saver smart pre-set battery power and management modes, 1 touch controls & high speed battery charging app features, you can solve battery problems & extend your battery life with our Battery Saver app. battery extender App can charger faster your Smartphone 30% & extend your battery life up to 30% by finding apps and settings that drain power on your device. Battery booster app also has features that can monitor & regulate power consumption.
When you connect your charger, Fast battery booster will detect it & limit the power consumption of your tablet/phone. Then your battery doesn’t withdraw much power during the time & therefore it can charge quickly. According to our tests, this will reduce charging time 40%-60% (depends on the Phone/Tablet)
Why Fast charging and battery saver is a MUST-HAVE app?
One-Click Optimization & its fast battery charger that can charge in 10 seconds
Instantly find & fix Battery percentage & Professional battery saver power consumption problems and unlock detailed settings to fine-tune your energy savings;
Phone Cooler
The cool down feature works systematically managing, monitoring and disabling CPU-intensive apps in order to protect your hardware;
Battery Saver & Battery Monitor
Fast charging and Battery Saver app Monitor all the applications that drain power while not in use & remind Mobile or Tablet user high consumption applications. How much battery will be extended if user use 1-tap saving. Fast charging Battery booster clearly shows the status of battery usage and life.
Convenient Power-Saving Widget
Our Fast Battery Charger will optimize your power consumption conveniently. Battery fast charger Display charge status in real time & estimating remaining charge time. Download from here https://play.google.com/store/apps/details?id=doctor.saver.battery.specialist.powermaster
Battery charger booster & Battery Saver is the easiest way to keep your Android Tablet phone working well when you need it & protect against slow charging.
Task Killer:
You can select the applications & kill them with just 1 tap.
Auto Kill: Kill the applications automatically. Keep your Tablet/phone in good condition all the time with our fast charging app.
Memory status: Show usage of your memory & also show the usage of every running Applications so that you know which app consumes the most memory.
Battery charger fast, Duluxe battery saver Key Features:
There are 3 modes in mobile battery saver application
Saving Mode: Only active Sms And phone suggest to be used in low battery status.
Sleep Mode: you can used during sleep which will turn off network sms and phone, turn on alarm clock
Customized Mode: You can customize frequently used modes.
- Accurately show battery time and status.
- Battery consumption optimization with 1 tap.
- Easy battery saving
- Enjoy the incredible power fast charging and never worry about your phone battery again!
How to use fast charging Battery Saver
- Run the app & turn on the fast charge mode.
- It will automatically boost charging speed when you connect the charger.
- Faster Charging Up to 20-30% faster than other fast charging, Battery Saver apps.
- Fast Battery Charging Features
- User-friendly UI.
- Shows capacity of the battery in the application.
- Automatically activate fast charging mode.
- Automatically turn off 3G, Wifi.
- Automatically turn off Bluetooth
- Fast charging is free app.
-Thanks for use our fast charging battery Saver app.
To clarify this, you're claiming that thanks to this app, my phone battery will charge in 10 seconds? That's what the above sentence implies.
Phone Cooler
A glorified task killer?
Task Killer:
It's a very well known fact that task killers do not work and will in fact worsen battery life as the OS will just restart apps it thinks it needs again. Why are you claiming it will increase your battery life and cool down your phone?
Thats also a Scarry amount of permissions that app asks for... If you don't trust the app with those permissions then you shouldn't install it.
The privacy policy also contains some bogus legal terms, that may not stand up if you are using the application in a country other than Pakistan.... if you aren't happy with them you certainly shouldn't use the application
