Caleb Swag Wolf
What is a good battery saving application that I can use on my LG Stylo because my battery is draining kinda slow and fast so can someone help me out here please?
I don't like to root my devices so therefore I need an app that works on non rooted devicesTry exposed moduals like greenify if your rooted. Wiping the cashe will also help your battery life. If your battery stats indicate goggle is causing heavy back ground usage try goggle fix from playstore.
I have the play store but what app can I use to save my battery?Then you will need play store.
I'd go with greenify or dr battery then. If check the user rating scores you can try others. I also like and recommend cclean.
Marshmallow (Android 6)What Android version are you using?
Android 6 has several options to save your battery, no need for rooting or 3rd apps.
Good news, Marshmallow has been built with battery saving in mind. You can enable Doze mode or put the apps you don't use often in hibernation.Marshmallow (Android 6)
Virgin MobileSo attempt greenify .
Which carrier are you using.
I agree. But what's gsam, can you give me a playstore link to it so that I can download it?Use Gsam to pinpoint your battery issue.
Use Greenify to use aggressive doze. No root required.
I still have my Stylo and the battery life improved when using these 2 apps.
Any other "battery saver" apps are pretty much garbage and actually make your phone work harder.
