Battery Schedule?
Is there any app's out there that you can put your wifi 3g gps etc on a schedule.
Mainly to turn off like 12:00 AM to save battery, and turn back on at whatever time you set?
I know there are some that will turn your wifi and 3g (user set) off if your battery gets below a certain point (user set) but these are like $3.00. To me it seems like a rip off, since its such a simple app...
Anyways does anyone know of an app like this, if not would anyone be interested in developing it? :D Seems simple for someone who knows how to create app's.
The reason I think this would be better than the battery manager's that just shut your data wifi and gps off after your battery hits a certain % is because sometimes your battery will be just charged but you will go to sleep at night leaving your wifi/3g on and your battery will drain until it hits whatever %, then the manager will turn your data off. Meanwhile you just lost a whole lot of battery that you didnt need to.
PS, is google going to add in a battery manager, or a sleep function to wifi and 3g in 3.0? It seems like a really good idea seeing as lots of people dont like the battery life, and ive found that by turning wifi and 3g off at night i save alot of battery.
