Help battery use in settings force closes
iamloco724
i just got the droid 2 and right away rooted..i ran into a problem and wanted to go back to stock basically it told me i was back in stock but i still wasnt able to update my phone
so i just installed the latest sbf file and got it up and running
now i like use the shortcut to the battery use in settings and everytime i hit it i get force close even after i reboot my phone
is there anyway to fix this
if not is there a simple alternative i can download that will tell me just battery use and i also like the info about min since unplugged
When you SBFd, did you also clear your cache and data?
no these are the instructions i followed..how would i do it that i can clear everything
Switch your device to PC mode
Turn on debugging mode (settings>applications>development>debugging mode)
Launch RSDLite (make sure device appears in window)
Select SBF
Start
Turn off your phone. Hold the x button while you press the power button. You can let go of the X after the Moto symbol shows up. This will show you a screen with a triangle with an exclamation point inside of it, and a little android. Open your keyboard and press the search key (magnifying glass? I have a D2G, I'm assuming these are the same) use the left and right keys on your keyboard to go up and down, and the ok button to select. (Or the volume up/down keys, and the camera button to select). Do both wipe data/factory reset and wipe cache partition when you're SBFing.
Edited to add: When you're done, just hit reboot system now.
you do this as the sbf is going or before u start it?
