Battery Widget
HeXiiK
Member
What is the best battery widget? I'm looking for one that tracks by each percent. I know BatteryLife is a good one, this one did by percent on my Hero, but now it wont on my X. Tell me what you guys use and what's best.
Battery Left kind of does it, but you need to calibrate it, and even then it's not always right, it's just an estimate. But I think that's about as good as you can do.
There are a ton that track down to the percent - some like battstatt display it in text; also check out batterydroid;
