battery will not take a charge
  • Start date Start date
A
Android Question
Guest
I have an android zte and just recently will not take a charge, using the same charger that came with the phone
Try using a different battery ...or a different charger. You just might have a good battery gone bad.
Also, you can learn more on your device by checking inside its area of support. You can do so by joining our community.
Best luck. ;)
