Battery won't charge past 93%
asdf12321
Hello guys, a very good day to you all.
My battery won't charge past 93%. That is, at 93% the phone thinks it's fully charged. I've had this phone since march, so I think it's a bit early for battery fatigue. So shall I:
1.- Try bump charging
2.- Use the delete battery stats options in CWM
3.- Forget it and go back to sleep
Cheers
I would first deleted the battery stats and then do a full power cycle (let the phone discharge to 0 ... 5% actually, the phone won't let it go to completely dead) and then charge to full, or as full as you can get it and then reboot.
If that doesn't fix it, I'd go for a warranty replacement only because if your battery is the problem, your phone's charging circuitry might have been the cause.
wait a mo it may just be your cap rate maximum it can be charged to lengthen the batteries life usualy its set to around 96 but its only 3% so it wouldnt hold much more charge than that so unless you root the phone then use franco kernel then you can change that from 93% to 100%
Might also turn it off to charge it if you're not already. My Droid 3 seems to have a problem getting to 100 unless I turn it off. Makes no sense to me as to why that's the case. My Thunderbolt never did that.
