Battery
If you go into settings>battery does it show any single app or process using an inordinate amount of power?
What's the app? It could be a rogue app ... one that won't shut down properly. Try rebooting the phone to see if that clears it up. If not, uninstall or disable the offending app.
Here is the screen shot, please help me the situation with my phone is dire as it keeps heating up my device
Sorry, please click on "battery usage" to list the apps that are using all your power. Then post a screen shot of that.
