AdrianC14
Android Expert
The BatteryLife widget by CurveFish is by far the best looking battery widget out there. This widget is 2x1 (this is a pro or con depending on your preference.) The BatteryLife widget is highly customizable. You have the option to change the color of the widget to either pink, lime, blue, orange, or red. You also have the option to change the color of the widget at certain points, for example, you set the widget to turn red when the battery is at 15%. You can also set the widget to show the temperature, voltage, and technology of the battery. I find the temperature to be very useful. I highly recommend this widget. The best thing is that it is free!
Pros
-Large, easy to read
-Customizable unlike other battery widgets
-FREE
Cons
-2x1 can be a little to big
Pros
-FREE
Cons
