beats audio installer broke my phone
  • Start date Start date
A
Android Question
Guest
I installed beats audio installer and every thing seamed normal when i rebooted my phone so i tried testing it out, i put on some music and nothing happens, no sound came out of the speakers even with the volume set to max, i got the same results when i plugged in headphones no sound came out of the headphones nor the speakers. Im also unable to record videos because i get an error. And i cant record my voice. And when i try to play a video it plays it fast with no sound no matter what video player i use, i tried the stock video player and mx player. So please help i need my music!
Welcome to AF, It will be recommend to the so called installer and test out the sound. If there is still no sound then a factory reset is needed.
I tried doing a factory reset but it still didnt work. I also tried uninstalling the app but nothing happened. I really need to fix it, anymore advice?
