since my update the other day, i cant get it to follow me from city to city? i have geotagging checked? also why are there 2 different settings for regular and then super clock settings? what is the difference?
I cant answer the geotag question as it works fine for me and I updated as well. Superclock is a completely different looking widget than home weather widget (U should see superclock as well as home weather when selecting widgets. also when opening beautiful widgets from the app draw configuring what is what becomes less confusing). superclock has its own seperate set of skins for downloading, options (you can choose it to show weather OR battery for example) ect.
yhink i figured out the geolocating thing but weather widget aint right. it shows a moon which is correct but description says sunny. i am using accuweather instead of google, what do you use?
