Beautiful Widgets Problem
Gulfstream
The home screen clock will not stay sync'ed with the correct time. When I turn the screen on it usually has the correct time then starts running slow or stops while using the phone...any ideas??
I am using Advanced Task Killer but I have it on the ignore list. This seems to have just cropped up in the last week or two as I never noticed it before. I'll try killing the task killer and see if that helps.
Do you kill the tasks automatically in ATK? If so, is BW added to bot the exclude list of apps in the main screen and also in the aout-kill exclude list?
I've notice that with the lastest update there is many FC galore. Had to restore the previous version. I also have the problem the OP is having. Boo hoo!
BW's clock is funky for me too... Too bad cause LauncherPro almost needs it coming from Sense UI... The battery drain from BW is pretty big too, since I've stopped using it the phone has a lot more juice in the bank...
I've updated to 3.11 a few times since it was posted on the Market. I always had the same results - force close. Got tired of it so I just restored the previous version. I don't think the dev is really listening to the users out there that are having issues of FC and the clock/weather not updating. I'll wait until the next update and go from there.
