Beautiful Widgets Problems...
Seddy
Hello All, Ive searched high and low for a fix for this and I couldn't find one so I'm reaching out for help. Back when I had my Samsung Moment, I purchased Beautiful Widgets and I've never had a problem. Just recently (I guess after an automatic update) I've run into a serious problem that i'm not too happy about.
Now, I would select my clock and weather skin, location, update interval etc. and place the home widget on my screen. Then after a few minutes the widget will reset itself back to the default and my location would no longer be saved. To get the widget back to the way I had it, I would have to go in a set everything up just for the self-reset to happen again like clockwork.
I've tried everything I could to find out what the issue was. I've uninstalled and reinstalled Beautiful Widgets, I've used different Launchers (Launcher Pro, Go Launcher, ADW etc.) I've even completely reset my phone and the issue still persists. I grew so irritated that I downloaded Fancy Widgets and I have no problem with that application. Unfortunately it doesn't compare to the flexibility of Beautiful Widgets and since I paid my hard earned money for the app, I would like for the issue to be fixed so I can go back to using it.
So my question to you guys is... Have any of you run across this problem? Do you know of a fix? Please post your inputs! Thanks in Advance!
-Seddy
-Seddy
Have you tried uninstalling the latest update to BW and going back to the previous version?
