Help because of bluetooth device is stuck on a bootloop
jhon doe
i have a problem, my device is stuck in a bootloop because my bluetooth is turned on i can't turn it off because my device reboots before i can disable the bluetooth. I must turn the bluetooth off to stop the bootloop is there any other way to turn bluetooth off?? will factory reset turn it off? can i recover my files after factory reset?? (i dont have back up)
A factory reset will wipe personal files. Can you boot into safe mode?
