Jupit3r
Member
The good:
Attractive design.
Great build quality.
Impressive performance.
Lots of connectivity options.
Android 9 Pie.
The bad:
No Netflix and Amazon Prime Video in HD.
32-bit version Android OS.
It has been a long time since the last time I was excited by a TV box. The other day I saw a video on ASBYT's YouTube Channel, introducing the Beelink GT King. I was so intrigued by the design and specs of this device, and decided that I had to get my hands on the box, and here we are.
The Beelink GT King is the latest addition to Beelink's TV box lineup, and it comes with some of the most astonishing specs ever seen in an Android TV box. Not only is it the first TV Box powered by the all new Amlogic S922X chipset, which has a big-LITTLE hexa-core CPU (4 cores of Cortex A73 clocked at 1.8GHz , 2 cores of Cortex-A53 clocked at 1.9GHz ), a beefy Mali-G52MP6 GPU clocked at 846MHz, and uses very advanced 12nm manufacturing process, it also comes with 4GB LPDDR4 RAM, 64GB eMMc storage, HDMI2.1 and a slew of connectivity options.
But what do those specs mean to us average consumers in our day to day use? Do we really need that much horsepower from a TV box? We will try to find out the answer in this review.
Main Specs of the Beelink GT King
Operating System: Android 9.0 (32-bit)
Processor: Amlogic S922X chipset (big.LITTLE Hexa-core CPU and Mali-G52MP6 GPU )
RAM: 4GB LPDDR4
Storage: 64GB eMMc Internal Storage, TF Card support (up to 128GB)
HDMI: HDMI 2.1 output up to 4K@75fps
Bluetooth: Bluetooth 4.1
Internet Access: dual-band WiFi 2.4G / 5.8G, Gigabit Ethernet
Ports: Ethernet port*1, SPDIF Port*1, DC-in port*1, Micro SD card slot*1, USB 3.0 Port*2, USB 2.0 Port*1, HDMI*1.
Dimension: 4.25 x 4.25 x 0.63 (L x W x H)
Power Supply: 12V DC/1.5A
Weight: 190g
Chassis: Black, Plastic
Retail Package: TV box*1, Remote control*1, HDMI cable*1, Power adapter*1, User manual*1
Retail Packaging
The Beelink GT King comes with very refined retail packaging, the half-skull on the front of the black box looks extremely cool.
Inside of the packaging we have found the GT King TV box, and some accessories: including an AC Adapter, an HDMI cable, a remote and a user manual. The user manual offers instructions in different languages: English, German, French and Japanese.
Design and build
The GT-King has a very premium and attractive design, definitely one of the best of all Beelink devices. The matte black finish of the shell looks pretty nice, while the highlighted skull on the top side looks identical to the one on the famous Skull Canyon mini PC.
Also on the top side, there's a raised Beelink logo on the top left corner.
The eyes of the skull will light up in green once the box is powered on, giving it a more interesting look.
There're lots of interfaces on the relatively small GT-King. The front plays host to an IR receiver, which works with the stock remote coming with the box.
On the left side, you can find two USB 3.0 ports, which ensure high-speed data transfer between the GT-King and USB-mounted storage such as a portable drive and a flash disk. There is also a MicroSD card slot, which can support cards up to 128GB.
The back side of the box sports an DC-in port, a USB 2.0 port, an HDMI 2.1 port, an Ethernet connector, an SPDIF port, a 3.5mm AV (RJ45) port.
There are 4 very short feet on the bottom side.
The GT-King measures 4.25 x 4.25 x 0.63 inches and weighs 190g, pretty compact even by TV box standards. The build quality is great, as the box looks extremely polished, with no ugly mold lines. It feels pretty sturdy, too.
The supplied remote is predictably lightweight, and feels very well-built as well. The box responds quickly to its commands and the infra-red range are acceptably long and broad. What puzzled me at first was that the infrared remote came with a USB receiver, which seemed quite unnecessary. I then contacted Beelink and they told me that the remote for the GT-King was designed to feature air mouse functionality, but due to the lack of material, they removed this feature from one batch of GT King. Well, I ended up being the unlucky few.
Setting it up
Setting up the Beelink GT-King is as easy as setting up any TV box. Connecting it to a TV set (or projector) via HDMI, plugging in the DC power adapter and you are good to go. After being powered on, a skull will show up on the TV screen, with its eyes blinking in different colors.
The startup is quite fast, as the familiar Beelink homescreen will show up only seconds afterwards.
System & Apps
The Beelink GT-King ships with Android 9.0 Pie, with the very familiar Beelink skin on top. The launcher has everything laid out beautifully and is very easy to navigate. The date and time is located at the top left with the temperature widget below. In the center of the screen you have a link to the media center, internet browser and Google Play Store, There are also shortcuts to "clear memory", app drawer, and settings laying below. To the right is an area where users can pin their favorite apps. Finally, at the bottom left you have shortcuts to power, volume, at the bottom right you have shortcuts to Wi-Fi, Bluetooth.
The navigation bar at the very bottom is defaulted to be hidden, but you can bring it up with a mouse. It has many virtual keys, including a power button, a back button, a home button, a recent apps button, a screenshot key, a volume- button, a volume+ button and a hide-bar button.
I personally think that Beelink should design a skin and some wallpapers more in line with the design of the GT-King, since this is such a special device, but developing something completely different for one device may be costly for such a small operation like Beelink.
The GT-King doesn't come loaded with bloatware, but there are some preinstalled apps. Besides the stock Google Play Store, Chrome, Calculator and Gallery, you can also find Beelink's very own App Store, Bee Files Explorer, Media Center, Movie Player and Bee Music in the app drawer.
The Google Play Store is the normal phone and tablet variant instead of the TV version found on many other Google certified TV boxes. Although there are more apps in the phone-version Play Store, you won't get most of your favorite TV apps here.
Still, you can install the TV version of YouTube, Netflix, Hulu, Amazon Prime Video from Beelink's very own App Store, those apps work better with a remote. If these are still not enough, there's always an option to directly install the apk files of the apps you want.
One thing we need to mention is that the GT-King runs on the 32-bit version of Android 9 Pie. There are a few apps which won't run properly on the device, but it is not really a concern for the majority of TV box users.
