M
Member 1979779
Guest
Hi there,
I've just got a new Beelink Mini MXiii android TV box.
It comes with "LightHome V1.1.1" launcher pre-installed from factory, as well as "DroidLogic System V5.1.1-20160425".
I hate the pre-installed launcher and the rubbish settings menu that comes with it, and want to strip it off.
I've tried to disable the above 2 apps, but ALL options except "Force Stop" are greyed out in the "App Info" menu, so I can't.
I've gone into MENU - SECURITY - DEVICE ADMINISTRATORS and the "LightHome" app has admin access. However if I try to un-tick it, it doesn't work. It just stays ticked, whereas other apps give me the option to disable admin rights to them.
I believe there is one way around this which is to boot in safe mode, but I can't find how to boot in safe mode from an android tv box, as there's no hard buttons and no option to press and hold the "Shut Down" option on-screen.
***Can anyone tell me how to get into safe mode, please?
Thanks in advance!
Thanks in advance!
