PDX_Dragon
Hello Folks:
I've spent many years writing many lines of C++ code for Windows. It's time to try Android apps.
Last night I installed Android Studio 4.0 and started the following tutorial by Caleb Curry:
It looks like a good tutorial, but I'm open to suggestions.
After several hours I'm wondering if my system is compatible with the Android Emulator Hypervisor Driver for AMD.
I've never run a virtual machine, so I'm probably doing something dumb.
My system's two years old with an AMD Ryzen 5 1600 processor. It's a low ball system purchased in early 2018 after my very nice laptop died, when prices for everything were through the roof.
The answer might be there, with the Ryzen 5 processor.
Someone responded to a question in Reddit that they're running 6 virtual machines on their AMD 1600:
https://www.reddit.com/r/Amd/comments/c9k4d7/virtual_machine_in_ryzen/
I'll go into more detail in case the processor's not the problem.
This site says I have to turn off three Windows features:
https://androidstudio.googleblog.com/2019/10/android-emulator-hypervisor-driver-for.html
Those features weren't turned on in my system:
The Component Installer started off all right:
And then:
This is what my BIOS screen looks like. See anything I need to do, or look at?
Suggestions?
Thanks
Larry
And then:
Suggestions?
Thanks
Larry
