rockcruze
EVERNOTE
Evernote is one of the most talked about online note taking applications. One special feature here is the drag-and-drop desktop version that allows you to see your notes and clips offline. You can use the Evernote mobile application for your Windows Mobile phone or iphone to capture pictures and record audio to send to your Evernote account. You can also email notes to Evernote using a secret email address. Youtube : YouTube - ‪The New Evernote‬‏
AHG Cloud Note
One of our favourites , AHG Cloud Note not only lets you take notes in a traditional way but offers added benefits like Cloud servers to store them , share them and access them from anywhere . With AHG Cloud note you can add imaged , Video , text and lot of your ideas to make your notes come live . Cloud Note is made for corporate and business users to simplify the process of creation of instructions, tutorials, knowledge base articles, field reports - and sharing them. Cloud Note makes it easy to capture and document process or procedure on the spot with your smartphone, by taking images / video and adding explanatory text, share and exchange documents, and integrate them into corporate systems, such as knowledge base or LMS.
Youtube : YouTube - ‪New business mobile application - AHG Cloud Note‬‏
Note Everything
A note (notepad) application where you can create text-, voice- and paint-notes. Your notes can be organized in folders. You can create shortcuts on home, send notes, use live folders & much more!
Youtube : YouTube - ‪The BEST Productivity Apps on Android Compared! - Everything Pro vs. Evernote - AppJudgment‬‏
ColorNote
With ColorNote for Android, you could easily take notes or create a checklist. The App is highly customizable and you could change the background color of the notes simply. You can even share notes and set a reminder for them. It does not sync with Google Tasks, but you could backup all your notes and checklists and save them on the phone. It will ask you for a master password and will encrypt all the notes. Notes can be searched by text or by voice and with ColorDict, a dictionary could be added too. The widget is also powerful and the App puts a reminder for a note on the status bar. ColorNote is really useful and the different colors make it attractive.
Youtube : YouTube - ‪Android User: ColorNote (FREE NOTE ANDROID APP)‬‏
AK Notepad.
With the app, you can write anything you want. Set a reminder based on your note, send your note by SMS or email. You can stik a note on your home screen for easy access. You can also customize the notes appearance and also sort or search notes by title. All with LED Notifications.
Youtube : YouTube - ‪AK Notepad Review‬‏
AHG Cloud Note
Note Everything
ColorNote
AK Notepad.
