Best Android battery/cpu/ram monitoring apps
What is your opinion on the current app i'm using?
  • It's a fine app
    Votes: 0 0.0%
  • There's better apps
    Votes: 0 0.0%
  • You don't need one
    Votes: 1 100.0%
  • Total voters
    1
  • Poll closed .
Unless you have issues, apps like this aren't really needed.
It's not been updated since 2012 either so the developer has abandoned it by the looks of things.
What do you need it for exactly? A problem or are you just curious?
I just like monitoring my phone what can I say I am a geek lol
Merged your new thread about the same topic in with your existing one.
As I've stated previously, unless you have a specific issue, these apps aren't really needed. That being said, if I were to pick one from the list, I'd go with GSAM Battery. As of Android 6.0, Google hid battery stats from anything that isn't a system app so you either need root, or ADB to get it working properly though.
I've not bothered monitoring temp or CPU usage for a while.
Edit - Just saw your reply. :)
I've also liked this in the past - https://play.google.com/store/apps/details?id=com.bartat.android.elixir&hl=en_US
Stats from every sensor if you're a geek :p
I've used DiskUsage - I have a copy on my phone, though I don't think I've started it once this calendar year (but it doesn't take up much space). And I keep a copy of GSam in case I want to find out what is using my battery in a little more detail than the system menu gives me. Its graphs can show you a history of things like battery temperature, cpu usage etc. I've never used any of the others.
But I've no interest in stuff like widgets constantly displaying live stats, so can't advise on that type of stuff.
