I am trying to find an app that I can search for a product and it will tell me what store has it. I have one called Shop Savy but that requires you to aim your phone at the barcode which is different from what I am asking.
Shop Savvy doesn't actually require you to scan a barcode. When you select "search for a product," it will bring up the camera by default, but you can choose instead to type in the product name by tapping the "Use Keypad" tab.
