Best Battery recommendations for replacement battery?
enduser2941
Member
Can anyone recommend the best replacement battery, perhaps an extended life replacement battery for the Inspire 4G? I have seen different posts with different recommendations so I figured I would just ask for anyone who has an Inspire, Desire HD what is recommended. Even with battery saver apps, and keeping my background apps to a minimum and having all service off that are not needed, the stock battery no longer lasts more then 1 hour off charge. I have a feeling that the current battery is just plain a POS. So hopefully you guys will have the best ideas on a replacement.
Thanks!
Thanks!
What do you guys think of Hyperion HTC Inspire 4G 2x Battery + Travel Charger (Also Compatable with Surround, and Desire HD)
