Accessories Best Clear Coated Shield Summarys
PhantomTrace
What do you believe is the best Clear Coated Shield?
(for example: Ghost Armor ~ BodyGuardz ~ Invisble Shield)
- Why is the product you choose the best?
~Does it have "orange peel" affect? after said-and-done
~Does the corners give you a problem? such as sticking-up-corners
~Is it really scratch resistant?
-Label any other pros and cons?
Side chat limited please....
I am the Corporate Evangelist for ZAGG Inc. creators of the invisibleSHIELD. I feel that I should explain why our product is the best and where we are coming from.
A lot of companies say that their product is superior to all the others out there for one reason or another. Let me tell you why ours is according to your post.
We are the originators of the idea of protecting an entire device with just a clear film instead of using a bulky case.
[FONT=&quot]The invisibleSHIELD film is also patented and exclusive to ZAGG. Any and all claims by other companies that their products have the same film or that they are "essentially the same" are just not true.
[/FONT]~Does it have "orange peel" affect? after said-and-done
Yes it does. The "orange peel" affect is one of the reasons that our film is better with the Nano-Memory Technology and self healing capacity that improves the invisibleSHIELD
