Help Best Conversion iTunes to S3 (DRM Removal)?
MikeSD
I'm wondering what the best way is to salvage my iTunes movies for use on S3. They won't play as is because of the DRM protection.
I don't need to do this wirelessly. USB is fine.
1) Do these conversion programs require playing the entire movie and just make a capture? This will take forever to strip hundreds of movies, if it does.
2) What is the best program for converting movies and TV shows from iTunes to the S3?
3) Which program does the coversion the quickest?
4) Which program produces the highest quality video after conversion?
I have teste the program from Aimersoft (DRM Media Converter) and it works but the video ouptut is very crapy. I would get far better quality by simply doing a screen capture. I wonder if I'm doing something wrong. It's also very slow. It takes longer than watching the video and doing a screen capture. And the filesize is larger than the original. Either I'm doing something wrong or there must be a better way, to get video of similar quality to the original.
Thanks,
