Paranoid android is really customizable
costarican....Where can I find the download for the Paranoid android rom? Thanks!
Look on the all the things root sticky it should be there
thanks guys!
Could you link me to any kernels for custom ROMs (cm 10.1 is what I have) any compatible with my Rom
http://forum.xda-developers.com/showthread.php?t=1804374 that's faux kernel its really good and it works amazing with cm10.1 that's what I'm running too
Lol I had the same issue, look for a thread called best ROM and kernel combo someone explained to me and there's screenshots on which one to downloadI was looking at that earlier and didn't know what link to click for kernal download
I'm running Xenon and loving it. Kernels are kind of debatable for the N7 right now
How so? Currently running Xenon with Franco r41 stable with good balance of batt and perf. What kernels have you tried that make you go meh?
Fair enough, course it depends on what you use device for and what tweaks you make to kernel settings. Takes a while experimenting with settings via Trickster (Play store) as well, Franco thread has some good pointers to various settings.
