jlede
Android Expert
So in my opinion this is the best feature packed ROM and even has something our tegra devices couldn't do before SREEN RECORDING which works flawlessly if I might add well here it is (hope I don't get in trouble for sharing) its the Mahdi 2.4 ROM
Edit:if you experience a bit of lagg on a clean flash its due to either the wallpaper and that on first boot its over clocked just simply go to build number or date and tap until Dev options are available then go to performance and set to desired speed or flash another kernal (guide for the new guys on how to fix some lagg)
Link to thread --->[ROM] [4.4.2] [GROUPER] Mahdi-Rom 2.4 [01/02] - xda-developers
DONT FORGET TO BACK UP APPS WITH HELIUM WHICH IS WHAT I USE FOR BACKING UP APPS AND THERE DATA (Replacement for titanium back up)
