Best Lockscreen w/PIN
Is there a way to allow you access to an app on your lockscreen without entering your PIN? The same way you can use your camera, but if you try to get any further, it stops you.
Since the Razr Maxx HD doesn't have the ability to just say "ok google" and it to listen, it'd be nice if you could at least access your search function or google now without having to enter your PIN.
I tried just using the google now widget, but it shows up small.
