Best power management app?
Kenneth196
Member
I just got the evo shift (and loving it) and I've always used power manager pro to control my phone's actions when it goes on the charger, taken off, and when the battery hits a certain percentage, etc.. as well as easy access to toggle wifi, bluetooth, etc.
I feel a little outdated however and I know there are newer management apps, with one coming to mind: juice defender. Is this similar/better than power manager? Just need some opinions and info about if the app works well on the evo shift. Thanks!!
Well, I tried JuiceDefender (also with paid version, the UltimateJuice!) but it will save battery ONLY if you have always enabled data connection (because it manages only data connection). EXCEPT that you have luck, and your device and kernel is known to Juice Defender and it can manage your device's processor speed (mine is not, hence I uninstalled it...)
