Root Best ROM?
I'm running Prime right now, but I've always been a fan of CYM (Cyanogen Mod) on my EVO, and noticed that there's a version available or in development for Transformer. Also I'm still on honeycomb and will want to upgrade to ICS as soon as all the bugs are ironed out... so...
What's the best ROM for the TF? (only issue I've had so far that might-or-might-not be ROM related is a slow typing speed when using the dock)
Right now I'm on revolver ROM. CM9 just couldn't support sd cards... (couldn't f****ing fix it) but if you're not a fan of using sdcards, then cm9 is the ROM for you
