Root Best rom?.
t12b25
Hi everybody, in your opinion what is the best rom for this phone?. What are my options?. Thank you for the help.
Anthony.
Just got this phone 2 weeks ago, what is still broken in CM? The one that I found has a lot of things broken.
If you read more than just the OP you'll see that GPS has been fixed and LED disabled, video recording is the only thing that remains. If no double tap to wake and video recording are deal breakers then don't flash.
Not real concerned with video, but I've gotten pretty used to the knock wake. Thanks for the response, I'll read deeper into the post next time. :P
I was also running the CM 12 Beta. I had no issues at all with GPS after I installed a patch I found.The WIFI worked ok except when I turned off the hotspot, it would crash and reboot the phone. Camera worked great though I never used the video. The LED also worked for me from the get go. I am on the MS631 5.1.1 right this moment. I was scouring the net for days and stubled across a ZUES HD V5 ROM for our phone and installed it to check it out too. Its not to bad. I have an updated version of the CM ROM from that post in my possession as we speak. I was going to wait to install it until I checked out the new MM update and unlocked my bootloader. I'm doing that here in just a few minutes. If any of you want to check out these ROMS, just let me know and I'll PM links to them. After I install this MM I'll upload the 2 ROMS onto one of my cloud drives and shoot ya a link. I also forgot to mention that the boot times with the ROM posted above; for me was excrutiating. Like 3 to 5 min boot times. Too long.
