Yes, you can use a Razr ROM, there are several listed in the All Things Root section in the regular Razr forum. There are a few ICS ports at this point. Personally I'm using the Axiom ICS ROM, it's not perfect yet (none of them are), but it's good enough to use as a daily driver. There are a couple of others that look like they'd probably be as good, I just haven't bothered to try them.
I'm not aware of any videos on it, and I wouldn't expect there to be a FULL write up on any ROM. What one person likes another person thinks is awful. Pretty much you just try them until you find one you like.
Note that it's only the front camera that doesn't work, the back camera works fine.
Thanks for that..I didnt know it was only the front camera, thats no big deal at all..
Anyone else have any other suggestions for any good performing ROMs? I really want to keep the stock ICS look (more or less)..
Until data drops on ICS roms are fixed, I am running Eclipse! Best rom for this phone so far. Smooth and fast.
I reckon that data drops are due to the radios and kernel not being made for ICS but for GB.
But by all means try them all!
