Best way to "clone" a Shield Portable?
dcpmark
I'm really bad at Android, so I need some help please.
I have a perfectly-set up Shield Portable running 4.4.2....it has most of the 64gb SD card filled with apps and games. I just bought a second one running the same, and I want it to have the same apps, app data, system settings, etc. I don't care about email, texts, contacts, etc.....I don't use the Portable for those things. I'm not talking about a "clone" that would require root....it can be a backup/restore, or just a copy/transfer, etc.
I did a little research, and found two possible apps: CLONEit and Easy Backup And Restore. I'm just not sure which to use, or if these are the right things to use, or if there is a better way.
Thanks in advance!
