Charles Chambers
When I play podcasts while carrying my cell phone in a pocket, android 11 will open apps or move items around on my home screen. What's the best way to stop this?
On a Samsung phone you can go into settings/home screen/lock home screen layout and tick the the option on. I don't know if that's an android or just a samsung option. The setting is a life saver for listening while on the move with a cell.When I play podcasts while carrying my cell phone in a pocket, android will open apps or move items around on my home screen. What's the best way to stop this?
It is both, I have it removed on my tablet.On a Samsung phone you can go into settings/home screen/lock home screen layout and tick the the option on. I don't know if that's an android or just a samsung option. The setting is a life saver for listening while on the move with a cell.
Some 3rd party launchers, such as Nova, give you the same feature on any Android phone.On a Samsung phone you can go into settings/home screen/lock home screen layout and tick the the option on. I don't know if that's an android or just a samsung option. The setting is a life saver for listening while on the move with a cell.
Thanks, I'll try this. My phone is a Motorola one 5G ace. I listen to podcasts when I walk my dog or am cleaning the house.On a Samsung phone you can go into settings/home screen/lock home screen layout and tick the the option on. I don't know if that's an android or just a samsung option. The setting is a life saver for listening while on the move with a cell.
Maybe turn off the display screen settings, what kind of app are you using to use the podcasts?Thanks, I'll try this. My phone is a Motorola one 5G ace. I listen to podcasts when I walk my dog or am cleaning the house.
