BetterCut, Apps Organizer, FolderOrganizer; Which is better for changing icons on home screens?
kratos
Back on my throne!!!
I've searched and found a lot of good information, but not quite what I'm looking for.
I am wanting to change the icons for a lot of my apps on my home screens. I have been looking at BetterCut, Apps Organizer, and Folder Organizer. Now Apps Organizer is free and Folder Organizer has a free trial version, but Better cut is not free not does BetterCut have a free trial version.
Please tell me what you like/dislike about the apps, primarily BetterCut and Folder Organizer (paid).
*How do they run?
*Are there any major bugs?
Is it easy to change the icons for apps on my home screens?
*Is BetterCut really worth $2?
*Is Folder Organizer really worth $1.35?
Are any of these going to meet my needs of wanting to change the icons on my home screens?
*Are the icons dependant on the app that changed them (in other words, if I uninstall BetterCut after changing an icon, will the icon still be what I changed it to, or will it go back to the default icon)?
*If you had $2 and could only choose one of these apps to change the icons on your home screen, which would you choose?
Please just tell me what you think and at least answer the * questions as those are the most important to me. I am going to play around with the two free versions of these apps and see if I like them, but unfortunately, BetterCut is an all or nothing app. I just don't want to feel like I wasted any money because the app ended up not doing what I wanted it to do.
Thank you for your replies and help.
Kratos
Try Any Cut. I believe it's the free version of Better Cut if I'm understanding right. I'm really not quite sure what there is available in Better Cut that isn't in Any Cut, but I use Any Cut and it does exactly what I want.
I own and use folderorganizer every day and as far as I can tell, approganizer is idential (and faster) if you're ONLY using it for app shortcuts.
I highly recommend either one if you want to organize apps into folders, and nested folders.
