Help Bh2 - help - im bricked!!
ok..so..i tried to put gingerbread on a BH2 - not realizing it would brick it >.<...did it mess up the partition on the system partition?? ive tried flashing back the original rom using Odin....even tried Recovery...still stuck in 'Boot Loop'
To do a factory data reset via recovery mode, hold the volume down key and send/end at the same time, then hit menu as soon as you see the screen image.
