Not sure if this is what you want, but in my mind what you are asking for is 'virtual surround sound'.
There are many apps that can deliver some form of this, but I am picky about sound quality and app quality as well.
I use quite a few different audio apps on my devices, but there are two that stand out to me as what may suit your needs.
https://play.google.com/store/apps/details?id=com.noozxoidelabs.eizo.rewirep
https://play.google.com/store/apps/details?id=com.noozxoidelabs.eizo.rewirepro
These apps are small enough to have both on your device at the same time.
Doing this will allow you to have six different audio presets saved (3 per app) to use on three different audio sound sources.
Remember that Android will only allow one audio enhancement app to run at a time, so the other(s) must be turned off before you start another.
Keep in mind also that the system in Android that maintains the 'only one audio app' protocol can get (for me, it is often) confused and malfunction, causing none of them to have an effect.
If this occurs, turn the apps off, and then restart the device and try again.
