I just put together the foundations for a simple game engine.
I was testing it with a mock background .png image. The image is 360px-640px 16:9. I tried loading it on a Nexus 5 and a Pixel 2 which are both 1080x1920. So the image should take up exactly 1/8th of the screen on both devises.
For some reason though not only is it larger than it should be but on each devise its being rendered at a different size. As you can see in the bellow image on the Pixel (right hand side) its taking up about 2/3rds of the screen and on the Nexus (left hand side) its taking up the whole screen.
![](https://i.ibb.co/1XhzJDC/Andriod-Test-1.png)
image hosting
Anyone know why this might be happening?
image hosting
Code:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:dist="http://schemas.android.com/apk/distribution"
package="com.example.magerush2">
<dist:module dist:instant="true" />
<application
android:allowBackup="true"
android:icon="@mipmap/ic_launcher"
android:label="@string/app_name"
android:roundIcon="@mipmap/ic_launcher_round"
android:supportsRtl="true"
android:theme="@style/AppTheme">
<activity android:name=".GameActivity"
android:screenOrientation="portrait"
android:theme="@style/AppTheme.Fullscreen"></activity>
<activity android:name=".MainActivity"
<intent-filter>
<action android:name="android.intent.action.MAIN"></action>
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
</application>
</manifest>
Java:
package com.example.magerush2;
import androidx.appcompat.app.AppCompatActivity;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.TextView;
public class MainActivity extends AppCompatActivity {
public static final String EXTRA_SOUND = "com.example.magerush2.EXTRA_SOUND";
public static final String EXTRA_CON = "com.example.magerush2.EXTRA_CON";
Button Play;
Button Continue;
Button Sound;
TextView txt;
Boolean soundflip = true;
Boolean continueflip = false;
@Override
setContentView(R.layout.activity_main);
txt = (TextView) findViewById(R.id.textView);
txt.setText("On");
Play = (Button) findViewById(R.id.buttonplay);
Play.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
opengame();
Continue = (Button) findViewById(R.id.buttoncontinue);
Continue.setOnClickListener(new View.OnClickListener() {
@Override
continueflip = true;
System.out.println(continueflip);
opengame();
Sound = (Button) findViewById(R.id.buttonsound);
Sound.setOnClickListener(new View.OnClickListener() {
@Override
soundflip = !soundflip;
if (soundflip) txt.setText("On");
if (!soundflip) txt.setText("Off");
public void opengame(){
Intent intent = new Intent(this, GameActivity.class);
String soundpass = "";
String conpass = "";
if (soundflip) soundpass = "1";
if (!soundflip) soundpass = "0";
if (continueflip) conpass = "1";
if (!continueflip) conpass = "0";
intent.putExtra(EXTRA_SOUND, soundpass);
intent.putExtra(EXTRA_CON, conpass);
startActivity(intent);
Java:
import android.app.Activity;
public class GameActivity extends Activity {
Boolean soundflip;
Boolean continueflip;
private TDView gameView;
private View decorView;
@Override
setContentView(R.layout.activity_game);
//Get veriables from main screen
Intent intent = getIntent();
String sound = intent.getStringExtra(MainActivity.EXTRA_SOUND);
String con = intent.getStringExtra(MainActivity.EXTRA_CON);
if (sound.equals("1")) soundflip = true;
if (sound.equals("0")) soundflip = false;
if (con.equals("1")) continueflip = true;
if (con.equals("0")) continueflip = false;
System.out.println("Sound is: " + soundflip);
System.out.println("Continue is: " + continueflip);
gameView = new TDView(this);
setContentView(gameView);
decorView = getWindow().getDecorView();
@Override
public void onWindowFocusChanged(boolean hasFocus) {
super.onWindowFocusChanged(hasFocus);
if(hasFocus){
decorView.setSystemUiVisibility(View.SYSTEM_UI_FLAG_IMMERSIVE_STICKY | View.SYSTEM_UI_FLAG_LAYOUT_FULLSCREEN | View.SYSTEM_UI_FLAG_LAYOUT_HIDE_NAVIGATION | View.SYSTEM_UI_FLAG_FULLSCREEN | View.SYSTEM_UI_FLAG_HIDE_NAVIGATION);
@Override
protected void onPause() {
super.onPause();
gameView.pause();
@Override
protected void onResume() {
super.onResume();
gameView.resume();
Java:
import android.content.Context;
import android.graphics.Canvas;
import android.graphics.Color;
import android.graphics.Paint;
import android.view.SurfaceHolder;
import android.view.SurfaceView;
public class TDView extends SurfaceView implements Runnable {
volatile Boolean playing;
Thread gameThread = null;
Background background;
public Paint paint;
public Canvas canvas;
public SurfaceHolder ourholder;
public TDView(Context context) {
super(context);
ourholder = getHolder();
paint = new Paint();
background = new Background(context);
@Override
public void run() {
while (playing) {
update();
draw();
control();
public void update(){
public void draw(){
if (ourholder.getSurface().isValid()){
canvas = ourholder.lockCanvas();
canvas.drawColor(Color.argb(255, 0, 0, 0));
int x = 0;
int y = 0;
canvas.drawBitmap(background.getBitmap(), x, y, paint);
ourholder.unlockCanvasAndPost(canvas);
public void control(){
public void pause(){
playing = false;
try {
gameThread.join();
} catch (InterruptedException e) {
e.printStackTrace();
public void resume(){
playing = true;
gameThread = new Thread(this);
gameThread.start();
Java:
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
public class Background {
public Bitmap bitmap;
public Background (Context context){
bitmap = BitmapFactory.decodeResource(context.getResources(), R.drawable.maintest);
public Bitmap getBitmap(){
return bitmap;
