blank card
  • Thread starter Thread starter sd card
  • Start date Start date
S
sd card
Guest
My phone froze so I. Try turning it off & on and it wouldn't doing so. I took the battery out, it really hit, waited for it to cool & put back. Now my sd card reads bla.nk or unsupported files what happened? What can I do?
Hi and welcome to Android forums.
Remove the SD card and see if the phone has any issues when the SD card isn't installed. That way we can rule out the phone being a factor. If you can, try another SD card in the phone and see if the new SD card is readable.
Can you remove the SD card and try it in your computer to see if it is readable? It might be that some data on the card is corrupted and if you don't have any data on there that is vital, your best bet might be to try a format via a computer.
