Help Blinking red light = Phone won't turn on
msjazz79
About 5 minutes ago, I was using my phone which had a full battery charge. I just went to try to do something on it and it's completely dead. I tried the power button and I received a blinking red light. I took the back off, took the battery out, reinserted the battery hooked up it to a power source and still it won't come back on. Does anyone have any suggestions?
check your sim and sd card... make sure both are still functioning and secured in place properly.... if its not that call customer support....
