Help Bluestacks 2/ WWE Supercard help
I have been using Bluestacks for a long time with minimal issues, but today I decided to try Bluestacks 2. Now when loading WWE Supercard it plays the game music but is stuck at the home screen. It is not logging into gamecenter/facebook (both are downloaded and logged in) it just sits at the screen. I uninstalled several times to no luck and even re installed the original Bluestacks and now it doesnt work. Help!
Bluestacks on a PC? Possibly something got changed or updated when you installed Bluestacks 2, but wasn't removed or reverted when you uninstalled Bluestacks 2. Be something like a Registry entry or a library file. What it actually is exactly, have no idea. You could try uninstalling Bluestacks again, and then look for any "Bluestacks" entries in the Registry using Regedit, and also in the system, and remove them.
You could try emailing the developer, but probably the game's developer doesn't support their game on anything but a real Android device, like a phone or tablet. Unless they state otherwise.
Bluestacks is the only place I would use it and have for over a year now. I have uninstalled Bluestacks 2 several times same with installing and uninstalling Bluestacks 1. May try rolling back computer at this point. I have emailed bluestacks but they take forever and yes the game is not supported but works. This is a main tool youtubers like my self use to record gameplay.
