Hi all,
I am new to Android and Java. Sorry to ask a stupid question. I am planning to write a bluetooth connection to control a robot. But there are no default bluetooth adapter in the Android emulator. Therefore, I write an alertDialog to remind that there is no default bluetooth adapter. But the alertDialog does not show. How to make it show?
Also, how to debug bluetooth code in the Android emulator as there is no default adapter? When I upload to my phone, it also has the application error. So any solution for that? Thanks!
Code:
public void onCreate(Bundle savedInstanceState) {
// Set up the window layout
setContentView(R.layout.setbluetooth);
if(D) Toast.makeText(this, "+++ ON CREATE +++", Toast.LENGTH_SHORT).show();
BlueTAdapter = BluetoothAdapter.getDefaultAdapter();
if (BlueTAdapter == null) {
Log.e(TAG, "It does not have a default bluetooth adapter");
//setResult(SetBluetooth.Result_Fail);
AlertDialog.Builder builder = new AlertDialog.Builder(this);
builder.setTitle("Warning")
.setMessage("It does not have a default bluetooth adapter")
.setCancelable(false)
.setPositiveButton("OK", new DialogInterface.OnClickListener() {
public void onClick(DialogInterface dialog, int id) {
dialog.dismiss();
}).create();
builder.show();
finish();
return;
