Bluetooth and screen lock
Okay people I have spent 4 hours of my life trying to find an apo/widget that will turn on the bluetooth and prevent the screen from going off. When I go to my car I currently have to go into the settings to prevent the screen from locking. I then have to prevent the screen from going in to standby. I then have to turn the bluetooth on. I use switch pro widget for controlling the bluetooth but I would love a one press widget. Anybody know of a solution.
Try "QuickSettings". You can have it in the notification bar, just slide it down, press quicksettings icon and you can turn on/off bluetooth and screen time out. You can customize it with other switches as well.
Okay guys thanks for all the help after talking to mate who put me on to switchpro widget he pointed out that i was being a bit of a mupet as switchpro does what i want (near enough) i just had to configure one of the unused switch action within switchpro widget to prevent the screen from timing out and another which is default configured to operate the bluetooth on and off.
What a mupet I am.
I must say switchpro is a fantastic tool now i know how to configure it LOL.
Again thanks for all the advice guys much appreciated.
