Tijuanatom
Any audio that I stream to bluetooth speakers (Supertooth Disco) or headphones (Jabra Halo) has a lot of static and an occasional (and very annoying) popping sound. I've tried a few different programs both streaming audio and playing directly from the SD card. I also tried using airplane mode to see if the other radios were causing the interference. I turned off all audio effects/EQ in the control panel also.
Everything sounds great wired directly to the speakers and my old phone doesn't have the same problem over bluetooth in the same environment.
Anyone else having the same issue? Any suggestions?
